Samsung Galaxy S21 FE (Fan Edition) is a variant of the S21 model and was released on January 11th 2022. The phone has a few changes from the main S21 model, making it slightly cheaper.
Sticky liquid in charger port
I spilt a soft drink and I think a small amount might've got in the charger port and dried, I think it might've dried directly on one (or more) of the pins so my phone won't charge with a cord, how can I fix this? Do I need to replace the whole charger port?
@xandersheals even if you don't replace the charging port (daughter board) you will still have to disassemble the phone and remove the board. Then clean it with some high grade isopropyl alcohol, a soft toothbrush and some cotton tip applicators. So the work is identical with replacing it. It's just a matter of how confident you are in removing whatever got spilled on it, and hopefully it did not shorten anything out. Something like this video will help you with that work.
Xander Sheals crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 848
