How do I replace brake pad sensors
Now that I replaced the pads, apparently, I need to replace the brake pad sensors. How is this done?
mitch1965, one end inserts into a receptacle behind the splash shield while the other end connects with clips to the brake pads. There are some great instructions on here. After replacing the sensor, turn the ignition key to the #2 position for around 30 seconds without turning over the engine...the light should now go out! Hope this helps, good luck
New features in centric brake pads are also being designed such as ensuring proper fitting to reduce the reverberation which occurs when there is hard braking. For more than ten years, centric has been earning appreciation and praise from racers and vehicle lovers.
@Amdad Pomy, how does your link help with the replacement of the pads? All you are linking to is a site that sells pads. You are not thinking about spamming on here?
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 17,589
