Seventh generation of iPad, released September 25, 2019, available in 32 or 128 GB models. Model Number A2197.
Screen glitching after glass/digitizer replacement **URGENT**
Backstory, I'm no professional but have been fixing iPhone/iPod Screens since I was 8 years old. I've always been the go-to to fix iPhone screens but have only ever been self taught from iFixIt Guides.
Anyways - I have tried to repair only my 2nd iPad ever from a family member the other day with just the worst luck. Everything has gone wrong with this repair and I'm so stressed at this point, I can't afford to dump any money into this as I believe I messed this up on my own.
Firstly, I was only asked to replace the screen as it was cracked. Ok, easy enough. Worked on it the other day and finally after 4 hours, got it all back together and done. Went to put the screen on and didn't realize the frame was gashed and CRACKED THE NEW SCREEN.
Anywhom, I said whatever and bought a new one and went to go replace it.
ISSUE THAT I NEED HELP WITH BELOW
  • Did a function test with the old cracked screen and the newly cracked screen. All was working as should.
  • After installing the new screen(2nd new one) it is now found that the LCD screen is glitching.
  • It is that "Ghost Touch" and moves the screen around, types in random passwords ETC.
  • I thought maybe it was the LCD itself. Replaced that, did not fix issue.
  • I tried with old glass digitizer, this ghost touch glitching problem is still there. I know it's not the digitizer.
  • Even if my hands are off the LCD screen and it is ONLY the LCD screen plugged in, I'm getting this ghost touch issue.
  • Checked the board connectors and all pins seemed fine. From a visual inspection of the Micro PCB connections, all looked to have no issue. Do not have a microscope, as I'm NOT A PROFESSIONAL. This was only confirmed from a visual inspection.
I really appreciate the help and support, as I've been stressed and really losing it over this thing. Not really sure where else to go.
Hi Bradley,
You're not the first person with this problem; go ahead and check out this previous question from another user with the same problems as you. There are quite a few possible solutions given, and hopefully one of them will work for you.
SOLVED: iPad doing its own thing! Ghost Touching - iPad 2 Wi-Fi EMC 2415 - iFixit
Bradley Florence crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 406
