The sixth generation of Ford's Falcon line, including the AU, BA and BF series.
Where is oil leak from
How to find where oil leaking from engine is
Use a flashlight to check underneath your car and around your engine – telltale drips might lead you right to the problem. There are several common locations for oil leaks in your car, including: At your oil pan gasket. At your oil filter or drain plug
rob hutchings crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 245
