If your Maytag laundry center washer is not starting, there are several things you can check to try to troubleshoot the issue:
- Check the power supply: Make sure that the laundry center is properly plugged in and that the outlet is working. Try plugging in another device to the same outlet to see if it works.
- Check the lid switch: The lid switch is a safety feature that prevents the washer from starting if the lid is not securely closed. Make sure that the lid is closed and latched properly. You can also try pressing down on the lid to see if the switch is working properly.
- Check the timer control: Make sure that the timer control is set to the correct setting and that it is working properly. If the timer control is not working, the washer may not start.
- Check the water supply: Make sure that the water supply is turned on and that the hoses are properly connected. If the washer does not have enough water, it may not start.
- Check for clogs: Check the drain hose and the pump for any clogs or blockages. If the washer cannot drain properly, it may not start.
- Check the motor: If none of the above solutions work, it is possible that there is an issue with the motor. You may need to take your laundry center to a qualified technician for repair.
Note that these are just some general troubleshooting tips and the specific steps may vary depending on the model of your Maytag laundry center washer. It's always a good idea to consult the user manual or contact Maytag customer support for further assistance.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
Hi,
What is the model number of the combo unit?
Does the dryer work OK?
Have you checked that the power supply for the unit is OK. Usually it requires 240V i.e. 2 x 120V power supplies separately fused.
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
