Tecno Mobile is a brand founded in 2006 in China with a focus on emerging markets. The product portfolio of the brand includes smartphones, tablets, push-button phones.
Blinking Light on Camon 11
The blinking front light is stuck on constant lighting and will not go off even when i switch off the phone. Should it be hardware problem causing that
This question was migrated from https://meta.ifixit.com/Answers.
If the blinking front light on your Camon 11 is stuck on constant lighting and does not turn off even when you switch off the phone, it could be a hardware problem. There may be an issue with the phone's circuitry or with the LED light itself. You could try a few things before taking the phone to a repair shop. First, try removing the battery and SIM card and leaving the phone off for a few minutes. Then, reinsert the battery and SIM card and turn the phone back on. If the issue persists, try performing a factory reset of the phone to see if that helps. If the problem still persists after trying these steps, it may be best to take the phone to a repair shop to get it checked by a professional.
Check breathing light in you setting
Most of the time the problem is attached to loss of knowing your setting so check "breathing light" in your setting
Roberts crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 320
