The Meta Quest 2 (formerly Oculus Quest 2) was released in October 2020 and is the successor to the Oculus Quest.
My VR headset wont turn on
So i had a scratch on my VR headset's an didn't know it, after trying to wipe it of countless of times i tried using Windex and now it wont turn on.. please help ;-;
nvm it turns on now but its just a black screen
@Cats Rule Do you hear any audio from the headset? Also what VR headset do you have?
@yukamoran i have a quest 2 and i do hear the audio
It's possible that using Windex or any other cleaning solution may have caused damage to the VR headset. Here are some troubleshooting steps you can try:
  1. Check the connections: Make sure that all the cables and connectors are properly connected to the VR headset. If any of them are loose or disconnected, try reconnecting them to see if that fixes the issue.
  2. Check the power source: Make sure that the VR headset is properly connected to a power source and that the power source is working. If you are using a battery, make sure it is fully charged and properly installed.
  3. Check for damage: Inspect the VR headset carefully for any signs of physical damage, such as cracks or breaks in the casing. If you find any damage, it may need to be repaired or replaced.
  4. Try a different power source: If you are using an AC adapter, try plugging it into a different outlet or power source to see if that makes a difference.
  5. Contact the manufacturer: If you have tried the above steps and are still experiencing issues, you may need to contact the manufacturer for further assistance. They may be able to provide additional troubleshooting steps or help you with a repair or replacement if necessary.
Cats Rule crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 433
