A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
Games keep crashing until I restart my pc?
I bought a custom built pc on offer up and everything is good but when I start a game it’s laggy and then it crashes I have to restart my pc about 2-3 times just for the games not to crash in that day it seems like it has to fully restart everyday just to play games any help would be appreciated (I’m new to computers so I don’t know much)
We need to know the make of motherboard, etc. in order to help.
But hey just like any product you purchase and it doesn't work properly take it back to the retailer.
It sounds like your PC is having issues running games smoothly, which could be caused by a variety of factors. Here are a few things you can try:
  1. Check if your PC meets the minimum requirements for the games you are trying to play. If your hardware is not powerful enough, it may struggle to run games smoothly.
  2. Update your graphics card drivers. Outdated or faulty drivers can cause performance issues in games.
  3. Check your PC's temperature. Overheating can cause lag and crashes. Make sure your PC's fans are working properly and that there is adequate airflow.
  4. Scan your PC for viruses and malware. Malicious software can cause performance issues and crashes.
  5. Try running the games in windowed mode or with lower graphics settings. This can reduce the strain on your hardware and make the game run more smoothly.
If none of these solutions work, you may need to take your PC to a professional for further diagnosis and repair.
Sounds like a problem with Windows such a setting or program conflicting.
You could try using a program like Easy Gamer Utility, myself and many users have used it and it does a pretty good job at fixing most game crashes.
Otherwise I would recommend you try reinstalling Windows!
hulazu crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 652
