The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
MacBook Air ifixit replacement battery is draining quickly
The
battery on my early 2014 MacBook Air was showing "Service" so I bought a new battery from iFixit.
Since I was going to be in there, I also got a 1 TB Aura Pro X2 SSD.
I installed 10.15.7 on the new Mac HD, followed the instructions to condition the battery.
My battery is draining very quickly. I logged out of iCloud and turned off Bluetooth and it helped slightly, but the battery continues to drain at a much higher rate than it did when new.
I've reset SMC, PRAM but didn't help.
Is this a problem with the battery or something about the SSD?
Is there anything I can do or should I try to put the old hard drive back in?
Help!
Let’s get a better view of things, install this Gem of an App CoconutBattery take a snapshot of the apps main window and post it here for us to see.
Appreciate the suggestion. Most of what I found in there I had already noted in the System Profile report or Activity Monitor. I found out what was happening from there.
I'm running Catalina, as it's the earliest version that has firmware for the hard drive I installed. The accountsd process was overdriving the CPU and this was causing the quick battery drain.
I completely signed out of iCloud and the issue went away. Turns out, this is a potential issue for Macs running 10.15.7.
Apparently this was/is a common problem on certain Mac models, mine's one of them. Just search for accountsd issue Catalina or some variant.
An example. https://macresearch.org/mac-accountsd-hi...
I'm keeping iCloud off for now, and it's behaving fine. Since this Mac can only go to Big Sur, am debating an upgrade, but we'll see.
Zafer Hamza crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 185
