Bought phone from pawn shop. Headset is locked.
Is there a way to get pass the PIN of the previous owner?
ylawrence59, try a reset. Check this link for the info:
"Steps to perform Master Reset
All configuration settings will be set back to their factory defaults. Personal data and downloaded content, however, will not be lost.
From the standby screen, press the Menu icon.
Locate and tap the Settings Icon.
Tap Security.
Tap Master Reset.
Tap Yes.
Enter the device security code, then tap Done. The device will reset. The default security code is 0000.
Steps to perform Master Clear
All configuration settings will be set back to their factory defaults. Also, all personal data (including contacts) and downloaded content will be erased.
Tap Security.
Tap Master Clear.
Tap Yes to continue.
Select the desired option to clear the contents of the optional microSD card.
Confirm the selections by tapping Yes.
Enter the device security code, then tap Done. The device will reset. The default security code is 0000."
Hope this helps, good luck
Just wanted to note, off topic I guess but viable - I saw "Pawn Shop" in the heading. I've had clients and set up systems for pawn shops since the mid 90's. By law they are required to record serial numbers and provide a copy of all pawns/buys to the local LEO agency. Pawn shops overall are a great place to buy used items, but...
Problem is, the backs of iPods/iPhones etc, get scratched up so badly they can't read off the S/N and don't know how to go into the General Settings and get it.
In my computer repair shop, I use a 30x loupe to get the s/n off the back and match it with the s/n when you go into General Settings and record them.
I guess I consider it a courtesy service, but, I did manage to reconnect a lady with her stolen iPod that passed through my shop.
Again, off topic, but a subject that I've really never seen mentioned in the forums ... and I have first hand experience with ... well, figured I would share it.
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 1,246
What model is it? is it the plus?
crwdns2934271:0crwdnd2934271:0 Jay crwdne2934271:0
If it is the plus try this out "First take the battery out, and put it back in. Now Hold the Sym button (on the keyboard) and the power button simultaneously. Now if you get to the triangle with the android symbol your on the right page. then select wipe data/factory reset by using the volume buttons. then to select, use the return key(on the keyboard). here for more.
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
