5th Generation Ford Taurus refreshed in 2008 from the Ford Five Hundred, and similar to the Mercury Milan.
Spark plugs and hoses
First off, I removed spark plugs and see black at the tip and also smell what seems to be gas?? Also can I get a vacuum hose diagram.. This question is actually for a 2006, could you still help??
Hi Aaron,
We'll need more information about the black on the spark plug; for instance, is it a dry powder coating indicating carbon fouling, or wet and oily which would be oil fouled. Wet, gasoline-soaked plugs indicate that the fuel is not being burned in the combustion chamber, for example if the engine is flooded or there's insufficient voltage to the plugs like with a bad coil.
Champion spark plugs has a page on reading the condition of the plugs that would be worth taking a look at.
Reading Spark Plugs Color
I'll have to leave it up to some of our other contributors to help out with the vacuum hose diagram; I didn't have any luck finding one myself.
Aaron Flores crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 150
