The DYMO LabelWriter 450 is a professional quality label printer for home and office use. Model number: 1750283
How do I replace ink cartridge?
Black ink is running low and not sure how to get to it to replace it?
Hi @keithpl,
Please verify the make and model number of the device that your question is about.
The Dymo LabelWriter 450 doesn't use ink. It is a thermal printer. The printer uses heat from a thermal print head to print on specially treated, heat-sensitive labels
I have a Dymo LabelWriter 400 Turbo, do I need to replace the ink cartridge or is there no ink on this model too?
@brenda27832
All 400 series Dymo LabelWriters are the thermal print type i.e. no ink
This is a termal printer, it does not use ink or toner, chances are your battery needs charging or replacing.
Why do I need a battery for the thermal printer if it has an electrical plug?
@gailstewart You are correct that the LabelWriter series are all corded. Are you having the same problem as the original question, of the printing fading out?
Keith crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 61
crwdns2959996:0crwdne2959996:0 2,543
