The smaller of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
Is MacBook Air 2012 screen compatible with 2013?
I bought the A1465 screen to fix the MacBook Air 2013 screen.
But it was the screen of the 2012 model and I know that the iSight camera cable doesn't compatiable
also, I don't need an iSight cable.
However ,the display and Wi-Fi cables look similar, are they compatible?
@dogsuand2su the LCD's should be compatible. what is not are the iSight cables, WiFi cable. Those do have different length, connectors etc.
Sadly, the cables are a different length between the 2012 and the newer 2013~ Early 2015 display assembly’s. Which you can see in these two images.
The raw LCD panels are the same, but it’s a bit of work to open the assembly to replace it. For a frame of reference here’s a MacBook Pro panel replacement yours is a bit different but it gives you an idea what’s involved MacBook Pro 13" Unibody Mid 2009 LCD Replacement
crwdns2886500:0Replace a display assembly compatible with the MacBook Air 11" Mid 2012 model A1465 laptop. Part #661-6624. 11.6 inch. 1366 x 768 Resolution.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
MacBook Air 11" (Mid 2012) Display Assembly
$249.99
crwdns2886500:0Replace a display compatible with the MacBook Air 11" Mid 2013 to Early 2015 model A1465 laptop. Part #661-7468, 661-02345. Includes the 1366 x 768 pixel 11.6 inch LCD screen, display cover, bezel, iSight Camera, clutch hinges, Wi-Fi antenna, iSight, and display cables.crwdne2886500:0
MacBook Air 11" (Mid 2013-Early 2015) Display Assembly
$164.99
minjae kim crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 456
