Info needed on keyboard backlighting
My PowerBook G4 didn't come with the option of a backlit keyboard, but from doing research, if i purchase the light sensors, and seeing where all the wires go, do i need to purchase a new keyboard too? I know one of the sensors plugs into the keyboard, and i have that plug on my keyboard. So will the keyboard on mine still light up?
My PowerBook is the A1095.
PPC G4 1.33 GHz Late 2004 model 15 Inch.
Mine isn't the later 2005 model. Mine still takes the DDR 2700 ram vs the newer DDR2 ram.
this is the specs from the system profile...
Model Name: PowerBook G4 15"
Model Identifier: PowerBook5,4
Processor Name: PowerPC G4 (1.1)
Processor Speed: 1.33 GHz
Number Of CPUs: 1
L2 Cache (per CPU): 512 KB
Memory: 1 GB
Bus Speed: 167 MHz
Boot ROM Version: 4.8.6f0
Actually there are two other components that are needed. In addition to the keyboard the upper case is different. The upper case has the fiber-optic ribbons which allow the keyboard to be backlit.
More info needed.. Depending on the PowerBook you have..
PowerBook G4(15-inch1.5/1.33GHz) & PowerBook G4(15-inch1.67/1.5Ghz) like Joe mentioned, is actually backlit via fiber optics on the top case..
PowerBook G4(15-inch Double-Layer SD) Has The lights in the keys like MacBook Pros
matthewfrey, mine is the first one you said. PowerBook G4(15-inch1.5/1.33GHz)
thereddrag0n crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 2,391
