Hi @djbwa
Unscrew the two screws shown in the second image you posted and then remove the panel.
Behind the panel you will find the evaporator unit, evaporator fan, defrost heater and the defrost thermostat.
Underneath the heater (and evap unit) there will be a hole which the drain tube connects to. You can't easily get to the tube itself but you can pour water down the hole and check if all of it gets to the evap pan under the refrigerator.
If the evap unit etc is all iced up and the drain is clear, then there may be a defrost problem.
This could be due to a faulty defrost heater, faulty defrost thermostat or a faulty defrost timer.
Here's the AFU1767BW parts list that may help. If there is a faulty part search online using the part number only to find suppliers that suit you best.
Be safety aware and always disconnect the power to the refrigerator before commencing any work inside the refrigerator
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
https://www.justanswer.com/appliance/8cc...
Or just do a full defrost, despite the "frost free" of the name, sometimes you need to defrost. Get an ice chest with ice, leave unplugged 24 hours, use a shop vac, or sponges and then towels after defrost.
crwdns2934271:0crwdnd2934271:0 leafybye crwdne2934271:0
@leafybye Thank you. Already have done that twice. Didn't work. I only get ice on the bottom that's why I think it's a clogged tube.
crwdns2934271:0crwdnd2934271:0 Deborah Binder crwdne2934271:0
