MacBook Pro 15" 2011 A1286 stuttering and slow
Hi all,
I have a problem with my MacBook Pro 15”, late 2011 with AMD Radeon HD 6770M dedicated video card and Intel HD 3000 integrated card
I use the computer occasionally at home and a few weeks ago I noticed that the battery was charging very slowly, I changed the power supply with a new original one and the problem remains.
I also changed the battery to a compatible one and the problem persists. Now for a few days I have also noticed that the computer after a few minutes from starting it jerks and becomes very slow.
However, this problem arises in several ways:
  • With the battery attached the problem is always from startup, if I try to enter safe mode the Mac shuts down at the end of loading.
  • If instead I disconnect the battery, the computer starts, sometimes it doesn't become slow while other times after a few minutes it starts to jerk and become slow.
  • In Safe Mode for the moment this problem doesn't seem to exist (without battery) In normal mode, when the machine doesn't lag I tried to do a GPU test and it works fine, so I assume it's not a video card problem.
UPDATE: If I do the SMC with the battery connected, the problem disappears for a few seconds or 1\2 minutes and then returns.
Do you have any suggestions? Thank you!
Let’s start checking the battery as your system age tells us it likely needs a new battery and/or the charging logic is having issues. Install this gem of an App! CoconutBattery post a snapshot of the apps main window with the battery tab extended so we can see things Adding images to an existing question
Nicola crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 263
