need to add engine oil after every three days without leaking show
why I need to add engine oil after every three days without leaking show up.
Hi @alsaadawi,
Check if there are signs of oily residue near the end of the exhaust pipe e.g. black soot deposits on the body of the car around the end of the pipe
If there is, the engine may be burning oil, not leaking oil where you can see it.
Alternatively get someone to follow you when you're driving and check for blue smoke coming from the exhaust pipe.
Here's a link that shows what blue smoke coming from the exhaust pipe might be caused by.
I’d check inside the coolant too for oil in case there a crack in the block or head somewhere.
crwdns2942667:0crwdne2942667:0 51
