Repair information for the 28 inch LED TV manufactured by Curtis International under the RCA name, with the model number RT2806.
RCA tv flashing vertical lines after 10 minutes of use
Have an RCA tv model RTU6549. Tv works totally fine for about 10 minutes then flashing vertical lines will appear off and on. This occurs on every hdmi port. Flashing is not consistent and sometimes will be totally fine for a few minutes at a time. Sound has no issues. What could be causing this?
@stewiee intermittent errors hare the hardest to find out. Could be originating from the main board but could be an issue on the panel drivers. Check for any components that may look "{different" Odd compared to the rest. Check the solder connections (check both sides of the boards. The solder should be shiney and silver dull and grey appearance could be a cold solder joint. This is one of the cases where I would try some freeze spray. Once the lines appear use the freeze spray and use it on some of the IC's on the main board first. See if and where it makes a difference. That should help you determine where it originates from. Not an easy task and it may take a while to find the properly part.
Mike stewie crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 456
