Will it run without the battery?
The battery is dead. It powers down within a minute or two after I unplug it. I'm concerned that the battery could develop issues, since it's dead and under charge 100% of the time.
Can I just pull the battery from it and reassemble it? I only use it plugged in at the moment. I realize it sounds weird, but it's an old iPad. (It's in the 'old folks home' part of its life) I really don't see using it seriously as a battery powered iPad depending on the battery, so why replace it. I just want it to be 'safe' if the battery decides to swell or overrun. In other words, I can't afford to replace it, and see no need to replace the battery, but would like to keep it working. Long question, I know...
Thanks...
No, it needs the battery. Easiest way is just to order a cheap battery to replace the one in it since you plan on opening anyway.
100% can confirm. These will not boot all the way most of the time without an installed battery.
RobCow crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,349
