First generation, based on the Ford C1 global platform.
My cars seatbelt indicator is not working properly
Hi
I have a 2008 mazda 3 and a couple years later of when i got it the seatbelt indicator started showing wrong.When i would move the thing that the seatbelt connects it would show that the seatbelt is plugged in when it really wasn't. But now the problem has gotten worse it always show that the seatbelts are plugged in even if i shake the thing that the seatbelts connect it always shows that they are plugged in . If someone knows anything about this please respond!
I have uploaded some more pictures of the seatbelt backle so you can see more clearly what type of seatbelt it is.
@Vagelis
Here's a video that may help.
Maybe go to the Mazda place and see if they can reset it possibly or tell you what would do that for free they may you never know unless you try Was there anything in the manual about that nowadays they don't help you do your brake pads in the manuals of new vehicles like the once did now they tell you to take it to the dealer which is outrageously priced
Not an answer but they may help you and check your fuses are the right size and installed properly for those lights
Hi,
Usually there's a switch contact in the seatbelt buckle that is operated when the seatbelt is inserted
You may have to gently prise the cover off the buckle and check if it has been jammed in the closed position
Do you know how the seat belt buckle opens or do you know any video that show how to open it.
@jayeff
I saw the video and when i have time i will open th seatbelt buckle
Vagelis crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 241
