Repair guides, disassembly, and troubleshooting information for the first generation Sony PlayStation 5 DualSense controller, successor to the DualShock series. Identified by model number CFI-ZCT1W and motherboard model BDM-010.
Faulty Headphone jack, only sound on right ear
Hello,
unfortunately my headphone jack is not working properly anymore. I wanted to stand up and go away but my leg was tangled in the cable of my headset and I didn’t notice. So the Controller flew away and hit the nearby table in a way that almost broke off the headset plugged into the headphone jack. This ended up destroying my headset and the headphone jack. Now I can only hear sound on the right side when I plug a new headset in. The only way I can hear sound left and right is when I push the headphone connector in a certain direction when it’s in the headphone jack. How could I probably fix this? Is there a way to bend the pins back inside the headphone jack?
Thank you in advance
Nik
Hi
You will need to ether replace the headphone jack on your controller of resolder a pin if one is loose
As I have said this is a soldering job so u would only recommend doing this if you have experience soldering very small things
You could replace the main board of the controller as well but that costs a lot for what your fixing
Here’s a link to the part you will need
https://www.ebay.co.uk/itm/234003568525?...
Hopefully this helps
Any questions please ask
Hey,
thank you for your answer and the link. Unfortunately I do not have any experience with soldering in general. I have inspected the headphone jack and it looks like it is very difficult to desolder and replace. To me it looks like you can’t even reach all joints with a soldering iron.
But I think I might try to replace it at some point in the future once I’ve gathered some experience with microsoldering.
Anyways, thank you again for helping me out!
@Nik Name
No problem!
Let me know if there’s anything else I can help with:-)
Nik Name crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 176
crwdns2942667:0crwdne2942667:0 4,949
