The Dell Inspiron 1526 was a laptop released in 2008 known for the a swap-able face plates and its portability.
2 blinking lights,fan on not booting?
Turn on my 1526 fan kick on but doesn't boot the buttons on the very top of console (under screen) 2 on the right blink the left says on normally these lights would be caps look (I think) and num lock... NEVER have had an issue in the 4 years I've owned it. Please help ....!
crwdns2889612:0crwdne2889612:0 -1
You may consider checking the ram. If you have a pair installed, remove them, put them back in and start up the system. If nothing then...
Remove both. Add one stick and try the system. If you have the same issue, remove that one and insert the other and try it.
Thank you John update: will not turn on now blue light in bottom left corner blinks makes a noise!! Did not get a chance to try the advice yet...
Thank you sir. It solved my problem on Dell insp. 6000.
Scott crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 2,596
