Released in May of 2019, the Xbox One S All Digital Edition (model number 1681) is a revision to the Original Xbox One S (released in 2016). This model of Xbox One S ships with no Blu-Ray Disc Drive (thus there is no disc slit at the front), exclusively providing downloadable and streamable entertainment.
HDMI port replacement help
Does anyone know if when I go to solder on a new HDMI port if I have to clean off all the old solder or can I just put the new one in place while the solder is still melted? (Aside from the data pins, unless I can do that without bridging any pins).
Jenna Williams you "sort of" remove it. you need flux and get all of those traces nicely tinned. HDMI ports are really not an easy solder job if you have never soldered components on a circuit board. Take a look at video like this and even this one starting at 3:10
yea clean off the old solder, so the new hdmi port has a good clean connection to the board,.
Jenna Williams crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 747
