These pump espresso machines are all very similar in operation, and a lot of the parts are common across the range. Most differences are external and/or cosmetic.
Why is water pouring from my steaming wand
With the steaming knob in the off position and the steaming button also off. Water is dripping from the steaming wand when the machine heats up. When I start to make an espresso water then pours out the wand.
I get about 125ml of water per espresso.
The espresso also tastes weaker and has less cream. I am using the same coffee I have always used.
I have also recently cleaned the espresso boiler plate as per the manufacturers guide and also descaled the machine.
How do I fix the issue?
Reviewed the side bar instructions for disassembling, cleaning, inspection and replacing worn parts?
I viewed the instructions here for disassembling te machine and cleaning it. I noticed that the closing knob was stuck in an open position after I took it apart.
I was able to solve the problem by cleaning around the closing knob and letting it move on and off again.
Great! Thank you for posting a solution and feedback!
Stella Bowen crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 435
