Small fully automatic coffee machines from Melitta. The Melitta Caffeo Solo makes approximately two cups of coffee at a time. Milk foam is only possible with the "Perfect Milk" variants.
Size of the grind
Hi,
I opened the Caffeo Solo for a cleanup and closed it back. Now when the motor grind, the size of the coffee grind is top big and the infusion is not happening. I tried to change the size of the grind, nothing changed.
Thks
Did you open the grinder? Follow this guide, open it and adjust it. This is a good opportunity for a replacement of the grindstones.
Thks for the quick answer ! I'll try next weekend and let you know.
I followed the tutorial but nothing changed. The size of the grind is still too big. I didn't see where to adjust so it might be that.
I don't know why, but this part does not appear in the english translation:
Jura Mahlsteine austauschen
If you want to watch the grinder, when opened, use an empty toilet roll.
I finally had time to unmount it and managed to fix it. The issue was that I did not screw properly the black ring (size selector) to the grinder. Thank you very much for your help.
Romain crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 971
