does this chromebook hace a hard drive which can be replaced
hard drive for chromebook. does this chromebook have a hard drive which can be replaced
Hi Wenfrey,
Assuming you've entered the correct device category for your question, then I'm afraid I have bad news for you; no, there is no separate hard drive that can be removed and replaced. From the device page itself:
Unfortunately for the repairability of this device, both the memory and flash storage are soldered directly to the motherboard.
Without specialized tools and expertise, us DIY-ers are out of luck with upgrading this laptop's storage. It can be done by experienced repair technicians, but it's a difficult process to unsolder those parts and even then you have to find a pin-compatible part with more storage that the system BIOS may or may not be able to handle.
So the short answer is, no, you can't replace the hard drive, sorry.
It has a eMMC sodered on Solid stade drive, there are models with 16GB or 32GB disks. The latter one beeing a little bit more rare. But, it does have a SD-card slot that supports storage extension, but probably not the answer you're looking for.
I've been looking into a possible mother board swap that would work in the stock enclosure, or at least with some modification but i haven't come to find anything suitable yet since i live in the EU and customs for every motherboard that might be compatible (at least physical) gets more than economically viable to order from the US.
crwdns2942667:0crwdne2942667:0 626
