MacBook Pro a1708 2017 13" | Unable to turn on at all
Hi! Seeking repair guidance to deconflict possible faults for my friend's Macbook Pro 13", 2017 model a1708.
Context:
- No water damage
- No notable issues prior to this failure
- Fans do not spin on startup
- Touchpad clicks have feedback
- Keyboard has absolutely no backlight(no keys at all)
- Power button on keyboard works because holding the power button for a couple of seconds makes the touchpad feedback go away
- SSD remains warm when macbook is 'switched on'(means when touchpad has feedback when pressed)
- Display remains dark all the way with no signs of lighting
- No sounds emitted regardless of volume up buttons and continuous mashing to multiple buttons
Solutions tried so far:
- Reset of SMC
- Connected it to another Macbook with Apple Configurator, does not enter DFU state when power, right shift, left control and command button is pressed.
- Disconnected the power and keyboard from the logic board and plugged in the power, touchpad receives feedback when pressed but still no signs of lighting up nor booting nor fan spinning
- Plugged in to external monitor with working USB C to HDMI connector when 'switching on' and Solution 3 but monitor does not receive any signal
Extra info:
- Battery seems to remain flat and able to hold charge
- I do not have a voltage checker/multimeter
- I am not very familiar with Apple repair processes but am familiar with normal PC/laptop fixing
Can anyone suggest any repair guides/process I can undertake to figure out the point of fault? I hope my post provides sufficient clarity. Any help is appreciated!
Thanks in advance!
Update:
I stripped everything.
I connected the logic board without ssd, and connected only the display. I was able to get the fan to start spinning, but no display at all appears. I also connected to my external monitor and nothing shows.
Thereafter- I slowly started to add the other components, in this order: keyboard > ssd > speakers. All returned the same result, fan spins once power is connected, no display, no lights at all on keyboard(not even caps lock), no sound. I have yet to reconnect everything as I am quite tired and am gonna take a quick break.
Any idea what could be the problem?
