A general-purpose audio device that transmits low audio frequencies to your ears.
Why is my subwoofer making a farting noise
I dropped my subwoofer out of my trunk accidentally I finally finished all the wiring and the setup and then boom it fell out of my trunk because it was on the edge. Someone please tell me how to fix it. it makes the same grinding/farting noise when its off and your pushing against it
This sounds like the voice coil has either been misaligned or the voice coil has been dented/misshaped. If you're very lucky you can hold the cone and gently move it from side to side to realign the voice coil. But most likely you'll need to rebuild or replace the sub. A slight voice coil misalignment can sometimes get better over time from normal use but that's a long shot.
Zuhair Khokhar crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 76
