The Dewalt Compact Hammer Drill DCD796D2BT 20V is an ideal power tool primarily used by concrete masons and construction workers. The motor provides more speed and the charge runs longer for improved productivity.
drill bit stuck inside dewalt impact drill
i have a dewalt impact drill and the bit is stuck, im pretty sure i put the wrong bit inside and now its stuck and ive tried everything to get it out and its not working, is there a way to take it apart and then take it out or is the answer just brute force, i dont really want to damage the actual drill, i dont understand how its stuck to be honest, i think the drill holds the square type of drill bit and i put a smooth drill bit inside to do a quick job and did not have the normal drill, if anyone has any recommendations that would be awesome thank you
If a drill bit is stuck in your DeWalt impact drill, there are a few steps you can try to remove it safely and avoid damaging the drill.
First, try using a pair of pliers to grip the stuck drill bit and gently twist it back and forth. This may help to loosen it from the chuck of the drill. If the drill bit is still stuck, try tapping the end of the drill bit with a hammer or other tool to loosen it further.
If the drill bit is still stuck, you may need to disassemble the chuck of the drill to remove the drill bit. To do this, use a wrench or pliers to loosen the chuck collar and remove it from the chuck. Then, use a screwdriver or other tool to remove the chuck jaws and any other components that may be blocking access to the stuck drill bit. Once these components are removed, you should be able to access the drill bit and remove it from the chuck.
john crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 8,682
