connect to Samsung 225 bw monitor
hi,
I want to connect my ibook g4 to my samsung 225 bw monitor. I've seen some discussions say that I need a mini vga, others dvi adapter, and other suggested fireware??? Not sure which to select, and money is tight so I don't want to purchase 1 thing and it not be.
please advice,
thanks,
edie
crwdns2889612:0crwdne2889612:0 -1
If your samsung monitor has a VGA input connector you need the mini VGA to VGA adapter and VGA cable (male to male):
http://www.welovemacs.com/m8639.html
If the monitor has composite video connector (yellow) then you need the mini VGA to video adapter and a composite cable (male to male):
http://www.bhphotovideo.com/c/product/25...
These two adapters do not carry audio signal so you'll also need an audio cable (male stereo mini jack connector on one side to 2 male RCA connectors to the other end) to connect the macbook audio line out to the monitor RCA ports.
Thank you so much!!! Especially, the pic's that helps out a lot!!! Once again, thank u!!!
You're welcome. Good luck :-)
edie crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 735
