The OnePlus 5 (OP5) is a 5th generation smartphone released June 20, 2017. It is the successor to the OnePlus 3T and predecessor to the OnePlus 5T.
After replace the earpiece module, phone is only restarting.
I was trying to replace earpiece module using this tutorial:
OnePlus 5 Earpiece Speaker Replacement
but after fold together everything phone is trying to wake up but like in title is only restarting.
There is only Oneplus logo and nothing more.
The recovery mode is not working.
Hi Radek,
Replacing the earpiece speaker on your phone is a bigger job than it would seem at first glance, having to pull the motherboard to get to it. Because of that, there are a lot of connectors that had to be removed and even I've been guilty of not getting them back in place all the time.
So my suggestion at this point is that you should probably go back through the whole procedure again, and this time be very careful to make sure all of the FPC connectors are plugged in and fully engaged; my bet is you're going to find one that isn't when you check them.
Good luck; let us know what you find!
So Jerry,
I did everything as you wrote, checked all plugins twice even cleaned them all and it still doesn't work. The screen with the oneplus and android logo appears and after a while it vibrates and shows the same thing again.
There is any way to check these plugins to know wchich one is maybe broken?
Radek Wyzuj crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 119
