Washer leaks from back
I took shell off ran med load.
Washer has drip under basket where it mounts to 4 support braces. What do I need 2 do?
Hi,
you may have to tip the washer over and check if you can see exactly where the leak is coming from. Pour a couple of litres of water into the tub and put some food dye in the water as it may be easier to see where it gets through.
If nothing comes out initially, run a cycle that causes the washer to agitate for a minute or so, just in case movement causes the leak and if still no good drain the water and check.
There is a gasket part #16 (Agitator, basket and tub diagram) under the tub where it may be coming from.
Also check the water drain pump connections as well
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 27
Hi,
What is the model number of the washer?
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
Hi jayeff. Thanks 4 responding. It's an oldie. Kenmore 110.92273100
crwdns2934271:0crwdnd2934271:0 Richard Salazar crwdne2934271:0
@jayeff hi. Kenmore #110.92273100
