Brother HL-L2380DW will not boot up.
LED display flashes blank white screen for a few seconds then shuts off briefly, cycles like this continually upon plugging into outlet. USB port connected to PC does not show any activity. Any suggestions on how to fix this? I've tried several variations of removing wall power and holding down power button.
crwdns2944067:05crwdne2944067:0
Does this printer have an internal or external power supply?
Internal power supply
@Matt P Do you have a multimeter?
Yes I have a multimeter
Matt, I currently have the same issue too, did you resolve your screen-flashing-on startup?
By HL-L2380DW will not turn on when I press them start button,
But if I unplug it from the wall and wait for about 10 minutes Then plug it back it will start ok.
Hi Matt,
Ran across a page that had a couple of suggestions that wouldn't have occurred to me, so they might be worth a try.
[SOLVED Brother Printer won't Turn On: How to Fix it|new_window=true]
Here's a summary of their suggestions.
  1. Disconnect and Connect the Power Cable
  2. Check the Power Cable and Printer’s Power Button
  3. Clean the Printer
  4. Check the Cartridge & Print Head
  5. Disconnect the USB
Read through items 3 and 4; there's a little more to them than the title would suggest.
Let us know what happens!
I tried pretty much all of that. I removed everything that could be easily removed (tray and cartridge) and also the side panels and I didn’t see anything out of the ordinary, like a paper jam or any other blockage. No burnt electronics smell anywhere either. I’ll look more into cleaning the internal stuff and checking the print head.
Reset the Network Settings to the Factory Settings
Press. (Settings) > All Settings > Network > Network Reset.
Reset Network? will be displayed. Press Yes.
Reboot OK? will be displayed. Press Yes for two seconds to confirm. The machine will restart.
Regards,
Will
crwdns2889612:0crwdne2889612:0 -1
Unfortunately, the printer will not boot into the OS, this suggestion will not work
Matt P crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 58
crwdns2942667:0crwdne2942667:0 1,962
