Repair guides for all Carrier furnaces, air conditioners, and more.
Help understanding my Carrier Weathermaker 9200.
I have 2. One upflow, the other downflow. Upflow works great, using it for comparison.
Downflow max temp at floor vent is 70 degrees- varies a couple degrees from vent to vent). (Upflow vents are around 90 degrees)
I can see blue flame at the “sight portal”. There is/was a smell similar to burnt resistor in the house. Checked furnace areas easily accessible to me for source found none. Fan runs
This question was migrated from https://meta.ifixit.com/Answers.
Hi @d544
Not sure if this information is relevant to your particular model variant (58MCA and 58MXA) but check if there is a LED fault code display on the control board or if not if there is any obvious component damage on the board at all. (see p.9-10 on the document linked).
What is the full model number of the unit? Perhaps check if there is a product info label on the unit somewhere (on the back?) rather than the brand/model name on the front.
Knowing the correct model number will help to find the correct spare parts if there is a faulty part that needs replacing.
Couldn’t wait. Called for service. After working on it for 3 hours, cleaning, looking at input gas pressure, igniters, valve, etc. , using camera to look at heat exchanger, saw rusted section, determined and recommended either new heat exchaner or complete new unit.
Thank you jayeff for your response.
Doug Shuberg crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 290
