A wireless, more traditional, video game controller produced by Nintendo for the Switch system. Model number: HAC-013.
How to remove completely stripped screw?
So I stripped the screw to the point where it’s just a round hole. I tried superglue and it didn’t work, so the hole is caked with the stuff as well. How can I remove this screw? I presume I would need a drill, but what kind of drill might work for the controller?
Hi
If it’s in a hole carefully drilling the screw head then removing what’s left with pliers is probably you best option
It it wasn’t in a hole you might be able to cut a slot into it for a flat head screw driver to go in into but this is probably not the best option for you
You could also try using a rubber band on the end of you screw driver
Hopefully this helps
Any questions please ask
C K, this is only to complete the excellent answer by @hellomacos; You could try these precision screw extractors.
I’ve had good success using those, in many cases.
crwdns2886500:0Four different sized extractor tools to help remove fasteners or screws with stripped heads. Driver head is claw shaped for maximum grip. Sizes range from 1.1mm to 2.0mm.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
Precision Screw Extractor Set
$24.99
[deleted] crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 109
crwdns2942667:0crwdne2942667:0 3,947
