Repair guides and support for the OnePlus 5T, an Android smartphone with a 6.01" AMOLED display. Released in November 2017. Successor to the OnePlus 5. Model number: A5010.
Newly-bought battery for OnePlus 5T does not charge anymore
Hey there,
I've recently bought a replacement battery for my 5T.
The replacement process went well, and all worked fine(for a bit).
On the packaging(and here) it says to charge the battery to 100% and keep charging it(which I did), let it drain completely, and then charge it back up.
Now, I did the charge up to 100% + the extra 2 hours yesterday, where everything worked fine.
I let it drain over the course of today, and plugged it in when the phone shut down, just as described.
Since then, it hasn't been charging, and keeps showing the screen described in this post, which incidentally was the very reason I bought this replacement.
What's happening? I'm confused, the charging worked just fine yesterday, so the charging plug shouldn't be the problem. Did I just get unlucky and receive a broken battery?
Thank you very much for any help/suggestions!
Anything is possible == bad battery, bad charging circuit, loose connection for the sense info from the battery to the charging circuit, bad charger or bad cable. Do more troubleshooting.
How should I do the troubleshooting?
I've already tested different cables and chargers, but I don't just have spare charging circuits, obviously.
Should I return the battery and try anew with a different one? Or do you think buying a charging circuit and trying it out would make more sense?
Thanks for your answer!
a confused Buyer crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 171
