The backlight is not turning on when I use it.
My friend found a green one of these and when we tried to use it the backlight is not turning on. I dont know if it is because the screen light is burnt out, or the fact that it has been sitting in a kitchen drawer for 6 years.
jaj there are two distinct possibilities. One, it is a failure on the backlight of the screen, which would be repaired by a screen replacement, iPod Nano 5th Generation Display Replacement
Two, it is a failure of the circuit that powers the screen's backlight on the main circuit board. There are no schematics for this iPod (or any other iPod really). You could check for failed components and hope it's the backlight coil. Or you could replace the logic board (as above PITA) iPod Nano 5th Generation Logic Board Assembly Replacement The failed backlight is actually a pretty common issue with the 5th Gen Nano.
crwdns2886500:0iPod Nano 5th Generation Logic Board Assemblycrwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937803:0crwdne2937803:0
crwdns2886500:0iPod Nano 5th Generation Displaycrwdne2886500:0
Well the iPod works fine besides the screen, but there is some light green spots on the back. i also had the thought that it may be water damaged cause of the spots, and the fact that it was in a kitchen drawer near the sink area.
But thank you for helping.
I think you need to replace the LCD as that could be causing the problem
iPod nano (5th Gen) Color Display
crwdns2886500:0Replace a malfunctioning or dim LCD display compatible with the fifth generation iPod nano.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$12.99
jaj crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 173
