HTC's affordable A9s. Released in September 2016 with Android 6.0 Marshmallow
Battery change and replacement
Hello, I have two htc One A9s and the batterys are nearly dead all the time. I wanna know, what replacement battery is the best, and how I should do the replacement, because i never opened a phone the "normal" way before. Are there some things, that could easly break and i should have for the repair, or is it only a replacement battery, but from wich source?
Thank you a lot!
I just finished with the replaement of screen and battery, and will publish a small instruction guide on here.
Look on YouTube for battery replacement of your phone. Will give you an idea of how easy or hard it will be for you.
Thanks, I will try that!
crwdns2957956:0crwdnd2957956:0crwdne2957956:0 crwdns2950251:0crwdne2950251:0
Hi Marten,
I found what looks like a fairly decent video on battery replacement on your phone. It goes step by step and gives you appropriate warnings when needed and also lists the tools used to do the repair. A T5 Torx driver looks like the most unique item you'll need.
HTC One A9 Battery Replacement Guide - RepairsUniverse - YouTube
Mostly I'd say work slowly and carefully while removing the screen. If you don't have a hot air gun, generally a hair dryer will work fine, or you can splurge a few bucks and buy iFixit's iOpener that works quite well.
In addition, you'll need some adhesive to resecure the screen in place when you're done; precut is definitely preferred. I always pick up at least a couple when I buy them; sometimes it's easy to get them mispositioned and when that happens you don't want to have to wait until you reorder it. There are also times when you might forget something and have to open the phone back up again; I've done that a few times myself.
Here's an example of the adhesive; if you look around at places like Amazon, AliExpress and eBay you'll find plenty more.
Amazon.com: BisLinks 2 x Front Housing LCD Adhesive Glue Tape Replacement for HTC One A9 : Cell Phones & Accessories
crwdns2886500:0No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
iOpener
$24.95
Hi Marten,
Sorry I didn't address this earlier, but as far as batteries go, I've generally had good luck with aftermarket batteries myself. To be safe, look for "Genuine HTC" batteries; those will be what came with the phone originally, but personally I generally try to find a good price on places like eBay, Amazon and AliExpress. Oh, and don't bother with those "gold" or "high capacity" batteries that promise hugely inflated mAh numbers; those have been pretty thoroughly debunked right here on iFixit. They're fine if you want to pay a premium price for an average battery, but otherwise skip them.
@dadibrokeit Okay, thanks!
Have you also found a screen replacement? The screen of this phone is completely beaten up...
@Marten You're in good shape with regard to replacing your screen; it's old enough that the prices have dropped significantly. The first one I came across was only about $11 USD,
https://www.etechparts.com/lcd-digitizer...
You can easily find more on Amazon, eBay and AliExpress or whatever site serves your location.
Okay thanks, I'm sorry, but I haven't been active for long as you may have noticed. I picked up that project yesterday so thanks a lot!
So, it seems like,that the A9s is completely different that the A9, found this out, because the outside differs.
Marten crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 960
