The Ebike wont charge after drain
I have a weird issue with my battery, when I plug the charger port to the battery it turns red for 7 seconds, then back to green, it remains forever green, wait some seconds plug it again the same process it repeats any solution ?
Sometimes the battery will get too low and the charger can't detect it. Unplug the charger from the wall, now plug in your bike, now plug the other end back into the wall. Unplug it from the wall, wait 5 seconds and plug it back into the wall. Do this 15-20 times, you're slowly recharging the battery by doing this, and hopefully the charger will then detect the battery again.
It sounds like your battery isn't charging properly, and the red-to-green light cycle could indicate that it's not getting a full charge. First, make sure the charger and cable are working well, and that there’s no dirt or damage interfering with the connection. If your battery is older, it might have trouble charging after being completely drained. Try resetting it by holding down the power button for 10-15 seconds, then plugging it back in. Also, test a different power outlet to rule out any issues with the source. If none of these work, it might be time to contact the manufacturer for support or consider replacing the battery.
Mixanti solo crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 195
