In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
Why my MacBook Air turns off Randomly
My laptop completely ran out of battery after 2 months of no use / no charging (I left it under the bed). When I tried to start it and didn’t work so I used the alt/shift/ctrl/power button technique. Took it a while but finally came back. Used it one day with no problems (plugged and unplugged) and the third day of use it started to shut down randomly (sometimes while loading the profile just after starting it). Is there any suggestion on what could be wrong or what to do?
Hi
When a device starts behaving like this it usually means that your batter is needing replaced
Leaving lithium battery’s sitting for a long time can cause them to degrade and stop working properly
Also the temperature and amount of battery cycles has a lot to do with it too
Here’s how to check your battery’s health(linked below)
https://www.coconut-flavour.com/coconutb...
If your cycles are above 500 and it says service anywhere that usually means that the battery is the issue
Here’s a link to the part you may need
https://store.ifixit.co.uk/products/macb...
Hopefully this helps
Any questions please ask
I really find this app makes the information easier to read and brings it together in a simpler presentation CoconutBattery the free version is only you need.
@danj
Thanks for the information!
Il add it to to my answer
DanCas crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 246
