Green Stripe on screen
I'm not sure what model TV I have but it is a 43". A section of the screen is a green hue from top to bottom. I only run a firestick on the TV but even when this is unplugged from the TV, the line is there. I've uploaded pictures but not sure if they will show
Update (10/26/2022)
crwdns2889612:0crwdne2889612:0
0
@steffieb There should be at least one or more stickers on the back of the TV or perhaps etched into the plastic, where the model number, etc. are printed.
Could you perhaps take a picture of what you see (both of the problem and any stickers/etchings), as high resolution as possible, and attach to your question? Adding images to existing questions
I have seen on a couple of occasions, where the manufacturer has used very low quality LED strips for the backlight, at least one of the strips get a off-coloured hue (often either green or yellow).
crwdns2934271:0crwdnd2934271:0 Geir Ove Andersen crwdne2934271:0
@steffieb solarization like this is most commonly a panel error. As you see it is 1/4 of the screen which most likeky corresponds with one of the ribbon cables that connect the driver board to the actual LCD. You could carefully check the ribbon cable for any obvious damage. If your total screen would look like that, it would most likely be either the t-con board or the main board. In this case it looks like a bad display panel. Check your on-board menu and lets us know if that looks solarized as well or if that shows normal.
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
what is the on board menu?
crwdns2934271:0crwdnd2934271:0 Stephanie Grondin crwdne2934271:0
