MacBook A1534 Power but no Display / Boot
Just bought a 2015 Retina second hand as a redo project (first for this year of macbook) and currently stuck with a problem, seller stated it had no life at all what was correct. Checked for water damage what it had none of, and could confirm that the battery light was showing what meant that it had current. Just stuck with working out what the problem is, tried every reset but nothing has helped.
Only issue I found was some parts on the motherboard are not attached (one pin out of the two on the image.)
As Old Turkey said, it looks like the speaker is disconnected, and it looks like the right-hand wifi antenna is disconnected. Neither of these will prevent it from booting. These A1534 models suffer CPU and SSD death, it would seem the former with yours. RIP, nothing that can be done I'm afraid.
Tom45 not an answer just a comment to clarify not quite sure what you mean by Pin. Maybe you can mark it on your image. Anyhow from what I can see, and I am old so I may not see clearly, but it looks like your Left speaker is not connected to your logic board (Red Box). Also, were you inquiring about the other part (Yellow box) since that is centered in your image.
Tom45 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 199
