SONOS PLAY 5 is the original, bigger room, bigger sound, all-in-one Sonos music player.
Does not power on when plugged in
My sonas 5 bought in 2014 2 speakers one ok the other is not power on when plugged in any one can give suggestion pl as I don't understand sonas is not having service or repair section thanks
You may need to restart the Sonos product by unplugging the power cord for 30 seconds and plugging it back in. Allow up to two minutes for the product to start back up, and try connecting to it again.
Regards,
Will
Hi,
I have found the problem and it's exactly as described by der Reparatur in Winterthur; Bridge Diode blown and internal fuse-3,15A. I have found the replacement parts at Pusterla.
SONOS PLAY:5 Reparatur – Der Reparateur – Repariert Elektronik
https://derreparateur.ch/sonos/sonos-pla...
Something caused the fuse to blow (it was melted plastic) and one internal diode of the bridge is shorted. On the next link to youtube, the person describes that the 400v Elko caps were slightly swollen and replaced them too, plus a smaller 100Uf cap. He also recommends replacing all capacitors.
https://www.youtube.com/watch?v=2R8hKdGT...
The problem with Sonos and many others is they run from Apps and the power supply is always energized. It will increase longevity if you unplug the device if not used regularly.
Repair cost by Sonos is 199.- in Switzerland.
https://www.isonatec.ch/sonos-reparatur
To do this with damaging the circuit board Pads/Traces, I require a professional grade de-soldering station with vacuum solder removal. I have a simple soldering station and it cannot supply the energy required to melt the solder and the risk of lifting the very small pads is great.
Good luck,
Mark
Venkata Ramanan crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 201
