Guides and repair information for the LG Exalt VN220. The LG Exalt VN220 (also called the LG Exalt or Exalt LTE) is a flip phone released in 2018.
Why is there dirt/dust in my screen?
I need to remove the screen to remove dirt/dust that is inside my screen and makes it hard to see things on my phone. How do I remove the screen?
Use a plastic prybar to lift up the edges of the screen. You can use a little heat if needed, but it's not necessary. The plastic lens will come off. Then carefully clean the screen and remove the old adhesive. You can use a little alcohol to help you remove some of the old adhesive, and use a plastic pry bar to scrape some of the adhesive away. Be careful not to damage the LCD or PCB board. If you think you might damage them, then you'll want to remove them from the frame. That's more work for you, though, and it's not necessary, so avoid that if possible.
Then you can replace the screen with a new screen and adhesive.
Rivka Sperling crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 71
