Released in July 2018, the 15" MacBook Pro, model A1990, features a 15.4 inch LED-Backlight display with True Tone technology, TouchID, and up to 6 Core i9 Processor.
Erratic fan behavior even after replacement?
My MacBook Pro A1990 fan began erratically spinning. I reset the SMC to no avail. Fan control will intermittently sense it as spinning, or will report it at 0RPM (which is when it begins spinning faster). I replaced the R fan which was the misbehaving fan, and this behavior remains. All the temperature sensors appear to be operating normal. Hardware test shows PPF003 PPF004 which is what it showed prior to fan replacement as well.
I'm at a loss, is there another part besides the logic board that could be responsible?
the ground isnt attached to anything then the aluminum taped hole shaped wire for your sensers
Is that assembly not part of the fan replacement?
If the behavior is the same after replacement, I would also look into your keyboard cable. As I'm sure you noted when you did the fan replacement, the fans actually connect to the keyboard's board, not the logic board. The cable which then connects this board to the logic board carries signals for both the fan and the keyboard. Apple tapes over the connector on the keyboard end, but it's possible this cable is bad, has come loose, or something to that effect.
Otherwise I would make sure the fan connector itself is sound, and the little locking latch is in place.
If not those, then it's very possible it's a logic board issues.
This ended up fixing the problem. There were no signs of damage to the cable, so odd to have failed, but replacement resolved the fan issue and the hardware test runs clean now.
@alingerj Fabulous! Thanks for keeping us posted. I always appreciate when folks let us know what actually fixed the problem so the next person with this issue has something concrete to go on.
@flannelist
Hi Alisha, sorry to bother you. I came across your article today, three years later, and I was wondering if I could still get your advice.
I have a MacBook Pro A1708 2016. After booting up, fan control software cannot detect the fan speed (0 RPM). I’ve already replaced the fan with a new one (visually, the fan is spinning), but the system still can’t detect it. The hardware test shows the error code PPF004.
According to your explanation, it seems that replacing the keyboard flex cable might solve the issue. However, my keyboard is functioning properly. Could you please help me understand the reason behind this? I’ve already cleaned the keyboard flex cable and its connector, but the fan is still not being detected. However, both the keyboard and trackpad are functioning normally. I’d like to ask—what are the chances of success if I replace this cable? It’s been difficult to find detailed information about this issue online. Thank you, and I look forward to your reply.
Josh Alinger crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 286
