The twelfth and final generation of the Cadillac Eldorado was introduced in 1992 as a two-door coupé.
Floor shifter lights up wrong gear.
Transmission has been rebuilt. Shifts great! It just lights up wrong gear. Unless I can get the light in park (P) or neutral (N) it will not start. I need to bypass safety switch or fix whatever lights up gears.
It sounds like you may have 2 separate issues going on here. 1: your shift cable needs adjusted to show the correct gear. And 2: you need to check the safety switch. That should be mounted on the transmission, so the light indicating the gear shouldn't have an effect on that. Is it properly connected?
Jeffrey Frye crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 78
