Repair guides and disassembly information for Lenovo's first-gen X1 Carbon laptops. Released in August 2012.
Screen white and coloured lines
I’ve had my laptop for a couple months now and a few days ago I recently say a small white dot appearing on the screen. I didn’t think nothing of it as I was watching Netflix on it and thought It was just the film. The next day I go open the laptop and see half of my screen is white and the rest has coloured lines. There appears to be a crack on the screen but when I power off the laptop there is no signs of cracks. If there anyway I can fix this.
Hi
The screen has been cracked and cannot be repaired, it needs to be replaced.
Here's an image to show the problem.
(click on image)
What is the model number of the laptop as shown on the information label on the bottom of the laptop? Knowing this will make it easier to find a replacement screen and to remove the old screen to replace it
Update (09/24/2022)
Hi,
That number is not showing any results so the best I can recommend is to use the following links to fix the problem.
Here's the hardware maintenance manual for the laptop series. (Note the Machine Types on page 1. e.g. 3443, 3444 etc- hopefully yours is one of these. The MT number should be on the info label on the bottom of the laptop).
Go to p.82 to view the procedure to remove/replace the LCD panel
Here's the parts list for the model series. Insert the Machine Type number of your laptop into the Search by product name, serial number, machine type Search box and click on the link that appears. This will give you the part numbers for all the compatible LCD panels. Search online using the part number only, to find suppliers that suit you best. Usually the part number can be found somewhere on the back of the LCD panel if you wish to verify that you're getting the same one as you have now.
TP00061A is the number I think
Bailey Bassett crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 591
