Repair and disassembly information for Framework's modular and upgradable laptop, now featuring 12th gen Intel CPUs, a 13.5" display, and swappable ports. Originally released July 2021.
I need little metric screws
I'm looking for small, metric fasteners for fixing a frame.work laptop computer.  Do you have or know a source for any that meet these specs?
  • M2 3.0mm fastener with a 4.5mm diameter, 0.7mm thick T5 head.
  • M1.6 1.5mm fastener with a 5.5mm diameter, 0.6mm thick T5 head.
  • M2 4.0mm fastener with a 4.6mm diameter, 0.6mm thick T5 head.
  • M2 5.75mm with a 4.6mm diameter, 0.8mm thick T5 head.
Unfortunately, frame.work does not sell these screws. Thanks.
As of recently, they have started stocking these screws on the frame.work Marketplace under the Parts category for $5 per pack and are categorized by where the screws will fit (top cover, bottom cover, and input cover).
Hi
I would try eBay or AliExpress as they have most things
EBay is most likely your best shot but have you considered asking framework directly as I know they are repair focused
They might sell you them if you ask for them nicely as they might not be available on the online store
Hopefully this helps
Any questions please ask
Frame.work says I should be able to find them "at my local hardware store." They have not offered to sell them to me. I cannot find the exact specs on eBay nor AliExpress. There are some close matches (phillips-head screws with smaller head diameters) which might work for the M2 screws.
@barkingdoggy
Possibly try the m2 ones
Have you asked about eBay sellers
Some might be able to make some custom for you:-)
I'll do that. I'm also considering using glue. See: https://nerdytechy.com/best-glue-for-ele...
@barkingdoggy
It sound like it could work but just remember it will be quite hard to take appart if you use glue:-)
@barkingdoggy Local electronics supply shops sell selections of small metric screws usually in plastic, divided boxes - or just loose.
John Redmond crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 755
