The Dyson 360 Eye, launched in 2014 for around $999, redefined autonomous cleaning with its 360-degree camera navigation, powerful motor, and mobile app control, making it an appealing choice for tech-savvy users seeking advanced cleaning solutions.
Dyson 360 Eye goes in circles
the issue is that one of the tracks is loose. would love to see a proper tear down of this vacuum to see how to replace tank tracks as i have a replacement. just stuck on how to remove old set without breaking the vac.
This is a common problem. Drive wheel slips on the central shaft. I have successfully repaired mine by drilling though the drive wheel (after taking the track off), through the central shaft and through the other side of the wheel. Then glue a steel pin all the way through. I actually used the same drill bit and cut it off - using it as the pin. The wheel now spins. I completed a youtube video on it. https://www.youtube.com/watch?v=2X2sU_Do...
Hi
Here’s a video on talking it apart
https://m.youtube.com/watch?v=KKaTijHnz0...
This video should take you through the steps of dismantling the device
I recommend cleaning the device from the inside of you decide to dismantle it
If you need any help along the way please let me know
Hopefully this helps
Any questions please ask
I have just done a complete disassembly of mine as one of the drive wheels stopped driving and the robot just went round in circles. You may be able to replace the drive belts by just removing the two small access panels on the bottom which allows the tracks to swivel out of the body. Remove the track covers on the sides of the tracks. It’s then a case of easing the tracks off over the wheels. The larger wheel will “slide” off if you align the notch in the lower edge.
Hope this helps. They are not easy to completely disassemble but for the time being I have restored drive to the track and currently working ok.
This is a common problem with this model. Drive wheel slips on the central shaft. I have successfully repaired mine by drilling though the drive wheel (after taking the track off), through the central shaft and through the other side of the wheel. Then glue a steel pin all the way through. I actually used the same drill bit and cut it off - using it as the pin. The wheel now spins. I completed a youtube video on it. https://www.youtube.com/watch?v=2X2sU_Do...
johncope73 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 1,491
