First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
Where Can I Buy A Replacement Battery?
Hello,
I own a Apple iPad 1st Generation 64GB 3G/GPS or A1337 of which when I plug in and attempt to turn on boot-loops. When I attempt to put it into DFU mode and plug it into a PC or Mac it will either immediately turn off (the iPad only boot-loops when plugged in) or if I used a adapter that allowed it to be plugged into power and the Mac or PC at the same time, it would not show up on iTunes. I'm 95% sure that it is a battery problem meaning I need a replacement battery. I looked on the iFixIt Store and the oldest iPad they supply parts for (let alone battery replacements) is the iPad 2 and anywhere else I could find that supplied battery replacements for the iPad 1st gen were on sketchy websites or hosted by sketchy sellers on places like EBay and AliExpress (even Wish at one point)
If anyone can help by sending a link or showing me a place to find a replacement battery I would be really grateful.
Thank you,
-Jenson
Your right about it being a battery issue!
Part: iPad Battery
Guide: iPad 3G Battery Replacement
crwdns2886500:0Replace a 6600 mAh battery compatible with iPad 1st Gen A1219 and A1337 models Wi-Fi and 3G. Battery model #A1315. 3.7 Volts (V). Part #616-0448.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
iPad Battery
$38.99
If you’re in the uk look for seller like Replace Base or repair outlet. Trusted sellers I use all the time.
Jenson Cutting crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 129
